How loud will my PC be?
Solved by Suffokation,
Hey mate, your PC will be quite... quite... But, i'd recommend downgrading the processor to a i5 4460 and then purchasing a more powerful GPU with the left over cash. I would recommend a GTX 960 M-ITX if you can fit it, or a 760 M-ITX.
Hope this helped.
Featured Topics
TheDarkLoS ·
bensinspade ·
Posted in Graphics Cards3 -
CloseTheDoor ·
Posted in New Builds and Planning7 -
pchelp ·
Posted in CPUs, Motherboards, and Memory14 -
pontikos ·
Posted in Troubleshooting2 -
10
wolfgangam ·
Posted in Windows3 -
