GTAV and CIV 5 Problems
Go to solution Solved by ADZ_123_!"£,
Okay so im troubleshooting my friends computer
Specs
CPU- AMD Phenom x4 965 @ 3.4 stock speed
RAM- 8gb ram @ 1333mhz
GPU- AMD 5750 1gb gddr5
MOBO- ASUS M5A97 r2.0
HDD- 1tb hdd
PSU- Thermaltake TR2 600w
The Problem
Everything within windows runs fine. Initially would blue screen when playing gtav but I've replaced a stick of ram and it no longer blue screens. however gtav will load up and play for a bit but when i enter a heist it will blur over grey and not load. if i continue playing eventually things will start turning black especially at night they go pitch black (cant see a thing). Civilizations V won't start up from steam at all i click the button then nothing happens.
What I've Done
Replaced ram with no effect to the problems (but still could be the ram slots)
Cloned hdd while it was blue screening with no effect.
Currently cloning hdd again to see if that solves the problem
Ran CCleaner and malwarebytes nothing bad found and cleaned up some things
Dust removed and man was it bad; I had to take it outside with a vacuum and 5+ minutes of blowing.
Dont know what to do if this clone fails
Please Help
Latest drivers?
Specs
HDD- 1tb hdd
The Problem
What I've Done
Please Help
https://linustechtips.com/topic/354463-gtav-and-civ-5-problems/
Specs
HDD- 1tb hdd
The Problem
What I've Done
Please Help
Latest drivers?
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/354463-gtav-and-civ-5-problems/#findComment-4816281
Hey ktechguy,
The problem with everything turning black is probably your brightness and contrast settings. Tweak those in your graphics control panel and in game.
Civ V starting up from steam but not doing anything is probably corrupt local game files. Go to your steam library, right click Civ V, Properties, Local files,
and verify the integrity of the game cache. Any random crashes of GTA V are probably issues with local files. Just try to use the repair wizards included in
the game launcher itself or on steam.
Hope it helped,
alenova
https://linustechtips.com/topic/354463-gtav-and-civ-5-problems/#findComment-4816491
Hey ktechguy,
Hope it helped,
alenova
Verified Civ no errors but i updated the bios (was 14 versions out of date.....) civ started up and ran. starting gtav now
https://linustechtips.com/topic/354463-gtav-and-civ-5-problems/#findComment-4816706
