Can I put a normal case fan on the CPU opt plug with out the CPU temp effecting the rpm
If you can set the speed in the BIOS manually yes, if not no.
In most BIOS you can....
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/354336-cpu-opt-fan/#findComment-4814604
