Hi,
I need help with opening a .lqr file. I am trying to find the music from a game and the only music is "Music.lqr". I have searched the internet for answers but I cant find any. Can anyone help me?
P.S. The game's name is War of the Ring from Liquid Entertainment.
-Andri
https://linustechtips.com/topic/354110-i-need-help/
LQR files are archives (like zip or rar) made using the Squeez algorithm if I'm not mistaken. 7-Zip might be able to open it or you'd have to find a compression app that can... That said 22 KB is not enough to contain any actual music... It's probably just an XML file or something inside that tells the game where the actual music is inside one of the larger asset files.
That said... a quick Google search turns up all of the music which someone has already scraped from the game files here: http://www.protoman.com/Music/Music/Lord%20of%20the%20Rings%20-%20War%20of%20the%20Ring/
https://linustechtips.com/topic/354110-i-need-help/#findComment-4813549
First off, welcome to the forum!
Second, you'll likely get more and better responses in the future, if you title your threads a little better.
Happy computing!
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
https://linustechtips.com/topic/354110-i-need-help/#findComment-4814275
