Wall mounted Monitors HELP! ( Quick reply )
Hey guys i have a Samsung SyncMaster B1630 and HP vs17 and i decided to wall mount my carpenter will come in sunday because the flat screen LCD will be mounted also and i want to included mine to work with so i need help and more info !
As long as those screens have a VESA compatible mounting holes it should be pretty straight forward, you'll need to make sure the sizing on it works with the mounting brackets or arms you plan to get. I believe the standard for VESA is 75x75mm or 100x100mm.
what do you need help and info on?
many i think i need correct size and measure
from google images looks like they are both the 100X100 VESA so you would just need to find 2 mounting brackets for them.
Measure the 4 holes that make a square on the back to make sure and just search for a wall mounting kit.
i don't know about wall mounting stuff yea i will ask some of it
Well it depends on each monitor since some VESA mounts vary, the most common are 75x75mm and 100x100mm for PC screens check the back of the screens on yours there should be mounting holes. For the mount itself there are many options where you can have a tilting wall mount or ones on an arm to move out of the way and give more flexibility.
http://www.amazon.com/ATDEC-TH-2250-VTP-Telehook-Screen-Fixed/dp/B003FVDZWQ
http://www.amazon.com/VideoSecu-Articulating-Monitor-Motion-ML12B/dp/B003O1UYHG/ref=sr_1_2?ie=UTF8&qid=1429844873&sr=8-2&
