Hello! This is like my 10th post reguarding the build, but I'm already down to ordering. I want to make this as cheap as I can without scimping on performance! This PC is gaming oriented, I will be overclocking/doing SLI Thanks!
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (Purchased For $0.00)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.89 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($100.98 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($55.99 @ Newegg)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($334.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case  ($56.98 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Total: $656.82
Generated by PCPartPicker 2015-04-23 20:28 EDT-0400
https://linustechtips.com/topic/353918-help-making-this-build-cheaper/
Were you planning to sli?
Yes, in the future
Better: http://pcpartpicker.com/p/dzM7qs
Best I could do:
Motherboard: ASRock Z97M Pro4 Micro ATX LGA1150 Motherboard  ($98.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($315.00 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($57.99 @ Micro Center)
Total: $631.84
Generated by PCPartPicker 2015-04-23 20:44 EDT-0400
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
Just a question, why the gigabyte over the MSI?
Also, I will be staying with the 200R, I love the design.
It's cheaper.
If you like the flatter and boxy design, take a look at the S340: http://pcpartpicker.com/part/nzxt-case-cas340wb1
The 200R isn't really a good value when >$45.
It's cheaper.
Will the S340 keep it cool inside? I don't plan on buying extra fans as of now.
It should be just fine until you sli--in which case getting better fans might be a good idea.
