I recently made a threat because my pc would not get out of sleep :(  http://linustechtips.com/main/topic/353465-pc-wont-get-out-of-of-sleep/
I tought maby update the bios of my ASUS h61m-K but i get this error in the bios update :unsure:  Security Verification has failed
Is there a fix?
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
https://linustechtips.com/topic/353578-bios-problems/
Redownload the BIOS, put it on a FAT32 formatted USB stick and try again.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/353578-bios-problems/#findComment-4805275
Are you flashing from EZFlash (or whatever it's called) in the BIOS itself or from Winblows?
https://linustechtips.com/topic/353578-bios-problems/#findComment-4805285
What's your current BIOS version, and which version are you trying to flash?
0801 is the latest
https://linustechtips.com/topic/353578-bios-problems/#findComment-4805340
Your best bet is to try and flash from DOS. Download the Asus utility, the BIOS, and make a bootable DOS USB flash drive. Put the files on the drive, boot from it and run the flash utility. Report back what happens there.
https://linustechtips.com/topic/353578-bios-problems/#findComment-4805377
I think it's the bios version cuz i don't get problems with the 0702 bios
https://linustechtips.com/topic/353578-bios-problems/#findComment-4805478
Is there a fix?
You made a threat. People are dangerous these days on forums ;)
Cpu:i5-4690k Gpu:r9 280x with some other things
https://linustechtips.com/topic/353578-bios-problems/#findComment-4805820
