All of my parts (sans case, which should be here tomorrow!!) arrived today for my first build!!
CPU: AMD FX 8350
GPU: ASUS Radeon R9290x
MoBo: ASUS M5A99FX
PSU: EVGA SuperNOVA 850w 80+ gold
SSD: 2x Intel 730 series 240 GBs each
RAM: G Skill Ripjaw X 16 GBs
HDD: WD 1TB Black series
Cooler: Corsair hydro H105
Case: NZXT H440 (Blue and black)
I'm working towards a blue/black themed build. The MoBo, RAM and Case are going to look so good together. I have BassPulse Pro speakers that are blue LEDs. It's all going to look so good when it's done! I'm super excited for all of this!
Probably a little OP for someone like me, but go big or go home, right? Ha. If I get hired on for this new job, when I get my apartment (plus a huge pay raise), I'm going to wall mount a ultra wide monitor centered under my 65" TV and have everything set up in the living room for casual or serious stuff. I'm so stoked.
https://linustechtips.com/topic/352785-first-build/
CPU: AMD FX 8350
MoBo: ASUS M5A99FX
no, no, no
swap to I5 4690k and a gtx 960.
go for the Crucial MX100 512 GB for $170
Hyper 212 EVO heatsink, its amazing and cheap.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/352785-first-build/#findComment-4795074
Good Luck!
Not the most optimal processor I learned (with the exact same motherboard and cpu) but the stuff itself isn't bad at all! (Really good actually, just bad compared to Intel's options)
The motherboard is a dream to work with. Hit me up if you have any questions relating to it. (Say if you need something and you lost the manual)
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/352785-first-build/#findComment-4795089
no, no, no
already bought everything
2 drives for raid 0/raid 1
that cooler cost more money, and in return is better. whats the issue? (other than it not being as cost efficient)
https://linustechtips.com/topic/352785-first-build/#findComment-4795100
I5 is better, trust me, i used to be running on an 8320, youd be better off with a 960 or R9 280x and the I5
Solitaire.
https://linustechtips.com/topic/352785-first-build/#findComment-4795121
i know i5 is better but he already bought everything
https://linustechtips.com/topic/352785-first-build/#findComment-4795133
Yeah, everything arrived today, except the case, like I said. I'm not terribly worried about Intel vs AMD stuff right now. I splurged on SSD and spent a little more than planned on GPU and the case. For my very first build, I'm just excited to put it all together and have something that is mine, that I put together. I suppose as I get more experienced, I'll learn some more about what's better for me, but for now, I'm just pretty pumped for everything!
https://linustechtips.com/topic/352785-first-build/#findComment-4795174
Good Luck!
Thank you! I know that, more often than not (i.e. basically all the time), Intel will beat out AMD. If I enjoy this as much as I assume I'm going to, Intel will probably be my choice in the future
https://linustechtips.com/topic/352785-first-build/#findComment-4795187
