I think I may have posted this in the wrong section, so I'm going to repost it here.
Original Post:
Hello LTT Community!  So I have recently acquired a blu ray/dvd combo drive for my PC.  $25.00 open box price at MicroCenter   :D.  So I went ahead a started ripping my blu ray collection to my external hard drive in preparation for my FreeNas Server build that is coming up in the next few week.  I had already done all of my DVDs months earlier using MakeMKV to make an .mkv file.  Then using Hand Break to convert into .mp4 files for storage.  I've done 4 blu rays with no problems.  But now I'm ripping my Star Wars complete saga blu rays.  Episode I and II went fine.  I got the .mp4 files to play.  But when I've completed Episodes III and IV I got an error that says the file are corrupt when I try to play them to make sure they are working.  The .mkv files are working fine.  I'm just having the issue when I convert it to the .mp4 with Hand Break.  Am I'm doing something wrong here or are there any fixes to this issue?
Thanks for the input!!
https://linustechtips.com/topic/352443-ripping-blu-rays-problems/
what Blue ray player is it? please let me know the specific name and model number, maybe its a ripping problem, or maybe it's a software problem.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
If the mkv files work, it sounds like a software problem. Try converting it using some other program.
TBH I prefer to keep my ripped files in mkv format.  It's just so much easier to work with.
Can you use .mkv files with Plex Media Server?
try somthing else then? I used to use prism. But i havent done it in ages
 http://download.cnet.com/Prism-Video-File-Converter-Free/3000-2194_4-10644345.html
I got the same issue with this program as well?  This issue is so weird after it has been working fine for me already.
You could also try a program called Leawo Blu-ray Ripper they have a trial one you can use.granted I have only had this for a few months now and I still getting use to it,but I did make a few disc and it worked great for me..
If you use AnyDVD make sure you get the right version of it as there is 2 different ones you need to have AnyDVD HD for Blu-Ray movies..
Using Leawo Blu-Ray ripper only allows me to rip 5 minute segments without purchasing to program.
Getting the movies onto my HDD is not the issue.  MakeMKV is working with all of my Blu-Rays.  The issue is when I go to convert that huge .mkv file into an .mp4 file.  Some error occurs and the .mp4 version will not play.  This is only occurring with some Blu-Rays tho.  My Amazing Spider-Man and Batman Blu-Rays converted just fine.  I can keep the .mkv file, but I'd rather not because those files are so large.  With my storage solution I'm planning to deploy in a few weeks is going to be used for movie/tv show .mp4's as well as other things.  I don't want the entire NAS to be just filled with movies.  I need it to store my other import files as well and then backup with crashplan.
