so i built my build last December and i am running windows 10 technical preview which is supposedly 64 bit, however i have had problems where all my games and applications have downloaded as 32-bit or x86.
Do i need chipset drivers or something what am i missing?
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/352417-64-bit/
most programs are still 32 bit and still being coded for 32 bit....you are probably fine and the easiest way to see if you have a 32 or 64 bit OS is by checking how much ram the computer recognizes or is able to use since 32bit can only use 3gb of ram and 64bit anything above
https://linustechtips.com/topic/352417-64-bit/#findComment-4791061
you can't just "make" 32 bit applications magically run is 64 bit, that would require the developer to re code the entire thing from scratch.
most apps are 32 bit, but that does not mean its better to have a 32 bit system, for example if you run a 32 bit game in a 32 bit system, the game will only be able to use 2.(something) gb of ram since windows takes some for himself
while in a 64 bit system if you have say 8gb of ram installed the game can only use 4, no more. leaving you with a comfy ram cushion for multi tasking because, firefox is a bitch and uses 600mb of ram for 3 tabs
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/352417-64-bit/#findComment-4791095
64bit OS are backwards compatible with 32bit software. Have been since 64bit OS came to mainstream. So it could be problem within Win10, regardless of version. You could try to run Minecraft in compability mode like force it to run in 32bit.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/352417-64-bit/#findComment-4791907
