Dear Dudes.
So recently I moved my build into a H440 case so it looks super sexy.
I have two Jetstream 980's which are 2.5 slot cards. Obviously this means it all pretty tight in there.
Yesterday I was playing GTA V and noticed one of my cards was hitting 77c at some point and the other was at around 10 degrees lower.
Would you guys be concerned? I have 3 120mm SP fans as front intakes (starting to think maybe I should have gone for AF fans).
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/352242-gpu-temps/
Not at all
When running on air, the top card is always hotter than the bottom. Both of your cards are well within acceptable temperatures.
https://linustechtips.com/topic/352242-gpu-temps/#findComment-4788587
Not at all
Yeah read that before 90c is max right? What do you think about the fans tho?
https://linustechtips.com/topic/352242-gpu-temps/#findComment-4788594
You could disable one of the cards for games that can be handled on a single one, like gta V
What would that achieve?
https://linustechtips.com/topic/352242-gpu-temps/#findComment-4788642
98 is the maximum, but never let your cards reach 90.
Your fans are fine; do not stress over your decision.
https://linustechtips.com/topic/352242-gpu-temps/#findComment-4788661
