Hi
Im new to pc's and and building pcs basically. I have done some research but of course still do not know all the terms so i might not always get what ur saying ahha. My question is though with the list i provide below good enought to build a good pc and if not should i replace, add, remove etc anything to make it better. Keep it mind by budget max is about $1250. Also if i have put the wrong spelling for any equipment please fix it :). Thanks for any tips.
U don't really need to bcs i did some research and i have some stuff:
Intel Core i5-4690k 3.5GHz
Nvidia GeForce EVGA GTX 970 4GB GDDR5
Viewsonic VX2263Smhl
Corsair Vengeance Blue 8GB DDR3 (2x4GB) 1600MHz
Gigabyte Z97X Gaming 5
Corsair CX Series 750W Modular 80 PLUS Bronze ATX 12V EPS 12V
WD Blue 1 TB 3.5 inch 7200RPM
BitFenix Ronin
Thanks!
https://linustechtips.com/topic/351571-first-build/
no SSD?
you wont need the 750 Watts unless you are going SLi later
but the CX is just an OK PSU
Evga PSU will be better and more reliable
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/351571-first-build/#findComment-4780026
PSU and monitor that i recommend to replace:
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply  ($48.98 @ Newegg)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor  ($139.93 @ B&H)
Total: $188.91
Generated by PCPartPicker 2015-04-20 04:29 EDT-0400
https://linustechtips.com/topic/351571-first-build/#findComment-4780035
Hi
Im new to pc's and and building pcs basically. I have done some research but of course still do not know all the terms so i might not always get what ur saying ahha. My question is though with the list i provide below good enought to build a good pc and if not should i replace, add, remove etc anything to make it better. Keep it mind by budget max is about $1250. Thanks for any tips.
BitFenix Ronin
Thanks!
If you like to do lots of multitasking then I can recommend 16gb of ram you can downgrade on that psu to a 650watt psu. Now a days for a pc you really need an ssd.
Welcome to the forum's and don't forget to follow your own topics. :D
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/351571-first-build/#findComment-4780046
Thx for the tips
Any ram recommended?
Any psu recommended?
Any ssd recommended?
https://linustechtips.com/topic/351571-first-build/#findComment-4780197
Could you recommend a SSD?
And could u specify the evga psu or is any model better?
http://pcpartpicker.com/part/crucial-internal-hard-drive-ct120bx100ssd1
http://pcpartpicker.com/part/evga-power-supply-220gs0550v1
these two
https://linustechtips.com/topic/351571-first-build/#findComment-4780199
Total: $188.91
Thx for the help! I will keep these as options.
https://linustechtips.com/topic/351571-first-build/#findComment-4780201
snip
First build starter pack:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($226.99 @ SuperBiiz)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($134.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($329.99 @ Micro Center)
Case: Corsair 200R ATX Mid Tower Case  ($56.98 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Total: $1174.99
Generated by PCPartPicker 2015-04-20 05:02 EDT-0400
https://linustechtips.com/topic/351571-first-build/#findComment-4780206
First build starter pack:  PCPartPicker part list / Price breakdown by merchant CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($226.99 @ SuperBiiz) CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.89 @ OutletPC) Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($134.99 @ Amazon) Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($64.75 @ OutletPC) Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($94.99 @ Amazon) Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC) Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($329.99 @ Micro Center) Case: Corsair 200R ATX Mid Tower Case  ($56.98 @ Newegg) Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US) Monitor: BenQ GL2460HM 60Hz 24.0" Monitor  ($139.93 @ B&H) Total: $1174.99Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-20 05:02 EDT-0400
So this setup can be set up and works well? Its in my prica range and seems real neat
https://linustechtips.com/topic/351571-first-build/#findComment-4780297
Yep everything there will work well together, the only things i'd look at changing would be the case since that's more of a personal preference thing, apart from that it's a solid system
https://linustechtips.com/topic/351571-first-build/#findComment-4780322
Just looked over all the prices and websites for shipping to aus etc and it seems good. Thanks for the help!
https://linustechtips.com/topic/351571-first-build/#findComment-4780437
