Ultra wide stand replacement?
Go to solution Solved by Tedster,
If the screen's vesa mountable, then just get a cheap VESA stand...
Hey, it has been awhile. Im looking into purchasing a replacement stand because 1. The LG stand looks like crap 2. Its pretty cheap. Any recommendation? Budget is below 50.
Remember a wise man once said, "You'll most likely hear/see more bad reviews from products than good, because if they get a good product, they won't bother to write a review, and if they got a bad product, they'll complain about the product" ~ SoftenButterCream
https://linustechtips.com/topic/351309-ultra-wide-stand-replacement/
If the monitor has VESA mount support then that opens up alot of possibilities for a stand, otherwise you're pretty much stuck with that one.
What model is the monitor?
