What exactly do you mean by i-- and --i?
Do you mean like this:
int i = 0;
int 0 = i;
int i = 0;
int 0 = i;
My question is if this is the same thing:
for( int i = 10 ; i >= 0 ; --i )
System.out.println( i );
for( int i = 10 ; i >= 0 ; i-- )
--i subtracts 1 right now. i-- uses the current value of i, then subtracts 1.
So in pseudocode:
int i = 5;
print(i--);
print(i);
this prints 5 and then 4.
print(--i);
print(i);
this prints 4 twice.
sudo chmod -R 000 /*
The following will modify the value before it assigns to the variable
int i = 5;int value = --i;// i = 4 and value = 4 int i = 5;int value = ++i;// i = 6 and value = 6
The following will assign the variable and then modify the value
int i = 5;int value = i--;// i = 4 and value = 5int i = 5;int value = i++;// i = 6 and value = 5
If you aren't assigning to a variable or passing to a method, then there's not really much of a difference. They will both still increment or decrement the value.
int i = 5;--i; // i = 4i--; // i = 3
Technically --i and ++i are slightly more efficient than i-- and i++ when considering the compiled code (without compiler optimization). However I'd be very surprised if compilers aren't optimizing it for you thus making them equivalent. Regardless, this micro-optimization wouldn't really be noticeable but I still prefer to use --i and ++i when I can anyway.
I am not sure what --i is, but i-- basically means:
i = i - 1;
So everytime you code comes across i--, it lower the var i with 1.
EDIT: better explanations above :P
These are types of incrementers. i-- is called a post-decrementer, and --i is a pre-decrementer.
Basically, if you were to use one of these within an operation, the time at which i is subtracted from would be different.
for example:
int a = 1;int c = --a;
so here both c and a would equal 0 because of the use of the PRE-decrementation. It would look at the value of a, which is 1, and then subtract from it, then assign that value to c.
If it was like this:
int a = 1;int c = a--;
c would equal 1 and a would equal 0 because of the POST-decrementation. c would look at the value of a, which is 1, assign it, and then a would be subtracted by 1.
These same principles apply to pre and post incrementers like i++ and ++i.
CPU: i7-4790K --- HEATSINK: NZXT Kraken X61 --- MOBO: Asus Z97-A --- GPU: GTX 970 Strix --- RAM: 16GB ADATA XPG --- SSD: 512GB MX100 | 256GB BX200 HDD: 1TB WD Black --- PSU: EVGA SuperNova G2 --- CASE: NZXT H440 --- DISPLAY3 x Dell U2414H --- KEYBOARD: Pok3r (Clears) --- MOUSE: Logitech G Pro --- OS: Windows 10
i-- means the expression has the value i, then i gets decremented.
--i decrements i before setting the value of the expression.
Example
x = 0
y = x++ => y is 0, x is 1
// y is set to x, then x gets incremented.
z = ++x => z is 1, z is 1
// x gets incremented , then z is equal to the incremented x.
I'm not sure if it ever matters in Java but in C++ with operator overloading, unless you specifically want a post increment it's generally better to use pre increment. Since a pre increment just returns the same object it can be much faster than a post increment which much create a copy of the object, increment the old object then return the copy.
1474412270.2748842
