Hello,
I dont know if it is my GPU but I think it is.
My PC keeps laging and after a couplearrow-10x10.png seconds it freezes.
I close my PC and turn it back on but I get no screen, but i can hear the sound of windows starting up.
After 1 hour or so I start my pc and it works perfectly again.
This error occured to me 3 times by now.
This happend to me while I was watching youtube and browsing the web.
The last time it happend I plugged my GPU out and cleaned it with a brush hoping this wil fix it and it did work after that.
Not that my PC is dusty or anything, Its rather clean.
PC specs:
- Asrock b85m pro4 MOBO
- I5 4590 3.3 Ghz
- 8 gb Balistix sport ram (2 4gb sticks)
- gigabyte gtx 750ti.
- seagate 1tb HDD
- be quiet! system power 7 450w 80+ silver
Thanks for responding. (sorry for my bad english)
https://linustechtips.com/topic/351125-gtx-750ti-problems/
Hello,
PC specs:
- I5 4590 3.3 Ghz
- seagate 1tb HDD
Is there a OC on the gpu ?
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
https://linustechtips.com/topic/351125-gtx-750ti-problems/#findComment-4774582
No there is no OCing.
I would try re seating the gpu / ram / power connectors ;
This is going to be hard to diagnose as you get it at random times .
https://linustechtips.com/topic/351125-gtx-750ti-problems/#findComment-4774622
