OBS Streaming Problem
Solved by MrLewisMHarris,
Has your upload speed always been around 1mbps? I know virgin media are notorious for throttling people that use their upload speeds aggressively.
(see more @ this link and that link)
The only other thing I can think of apart from this is that maybe you're PC can't keep up encoding so much gameplay so it just starts to lag. It all depends on your OBS settings I guess. Just fiddle about with it, turn some settings down, but keep in mind that lowering your bitrate will stress your CPU more (because it's actually trying to encode more data).
