Gtx 960 psu problem
Go to solution Solved by CalebTheEternal,
960 will be fine
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-960/specifications
But why did you spend so much on a CPU and not a GPU?
Hi guys
I just built a pc and planning to get a graphics card.
Here are the specs:
Cpu: i7 4790k
Motherboard: Msi Z97i AC
Ram: HyperX 16GB DDR3 2400MHz (8GBx2)
Power Supply: ANTEC NE400C-BR NeoEco 400W 80Plus Bronze
Case: jonsbo v3+ (Mini ITX)
[EDIT](Forgot the ssd)SSD: Samsung 850pro 256gb
Here are the two options of graphics card:
Gtx 750Ti
or
Gtx 960
The problem is, I have a 400w psu and I don't want to spend extra money to buy a new one. Is a 400w psu powerful enough to push the 960? Even if it can, will it cause any damage to the psu?
Many thanks
sunnytse1
https://linustechtips.com/topic/349810-gtx-960-psu-problem/
960 will be fine
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/349810-gtx-960-psu-problem/#findComment-4759253
snip
Between the two, the 960 will be the best and yes, can be run by your PSU.
If I may ask, why didnt you go with an i5 or a Xeon instead of the i7?
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/349810-gtx-960-psu-problem/#findComment-4759258
Why the hell is that the rest of your system and you want to get a 750 Ti or 960? You know what, I don't even want to know why. Total system draw should be just over 200 Watts under full load, you don't have to worry.
https://linustechtips.com/topic/349810-gtx-960-psu-problem/#findComment-4759261
