Purpose: Video editing, streaming, Gaming (max star citizen)
Secondary Purpose: Looks cool, best price to performance (discount (forget) amd), lasts me until college (I've just turned 16)
Budget: 2200USD (if you want to modify the build PLEASE use mine as the base, as it has custom parts)
Things to note: 2nd monitor is for twitch chat, I am not a expert on mics so any suggestions
The link:www.pcpartpicker.com/p/pJVDNG
Thanks!
Things in build state: Lan room , Gaming PC
Things finished: Lol wut
https://linustechtips.com/topic/349273-thoughts-on-my-build/
a great cheap mic is the blue snowball, i love it, only problem i have with it is it doesn't have a mute button
and 404 error on the build page
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/349273-thoughts-on-my-build/#findComment-4752918
here is a build that has one good moniter to game on and one ok one to view chat on also it has nore than powerful enough cpu( you could go down to 5820k and then get better 2nd moniter) but this build will kick but and get you great frames in game and in stream at 1080p:
http://pcpartpicker.com/p/mBbwXL
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/349273-thoughts-on-my-build/#findComment-4752980
It looks pretty good, but if you're going for the black red look, i'd suggest you the asus strix gtx 970. Also, switch out the HDD for a western digital and consider the logitech g502 mouse.
Also gray you forgot to include the price of peripherals and windows OS. That build exceeds 2200
https://linustechtips.com/topic/349273-thoughts-on-my-build/#findComment-4752985
 i dont recommend the rajintek trition
it looks super baller, but alot of reviews on newegg show broken pumps, leaks, and DOA units
https://linustechtips.com/topic/349273-thoughts-on-my-build/#findComment-4753036
https://linustechtips.com/topic/349273-thoughts-on-my-build/#findComment-4753049
Someone said to switch from WD to that one for relyability
https://linustechtips.com/topic/349273-thoughts-on-my-build/#findComment-4753068
Have a recommendation?
enermax liqtech 240
https://linustechtips.com/topic/349273-thoughts-on-my-build/#findComment-4753082
