Hello LTT! I have a small issue with bsods. My build is this:
http://pcpartpicker.com/p/nwTMdC
Every once and a while, I get BSODs. Nothing big, it just worries me. Is there any solution?
Pentium G3258, R9 280X, Corsair CS600M, Gigabyte GA-H81M-H, 2 Random monitors, a no-name keyboard, a cheap $15 Logitech mouse.
LG G3 Vigor
https://linustechtips.com/topic/349272-bsods-every-once-and-a-while/
usually either RAM or HDD dying.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
run some stress test on it and see if you can get it to crash
I would use burnintest pro
30 day trial if you want
If I can get it to crash, I will post a picture.
I bought it around thanksgiving of last year. Coud something have failed already?
LG G3 Vigor
ofc. Hardware can break anytime it wants. It usually doesnt though ^^
Try stress testing like already mentioned
and maybe run Memtest to make sure its not the ram.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
the burnintest has a memtest ..I usually find actually testing in os better
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
ofc. Hardware can break anytime it wants. It usually doesnt though ^^Try stress testing like already mentionedand maybe run Memtest to make sure its not the ram.
I'll look into it!
LG G3 Vigor
well its easier but you can't test 100% of your ram that way. Should be ok though.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Ok, I got a crash while playing minecraft. Here are the the error report and files. The DMP wont upload, though.
Problem signature:
  Problem Event Name: BlueScreen
  OS Version: 6.1.7600.2.0.0.256.1
  Locale ID: 1033
Additional information about the problem:
  BCCode: 3b
  BCP1: 00000000C0000005
  BCP2: FFFFF9600029BBE6
  BCP3: FFFFF880093F7F10
  BCP4: 0000000000000000
  OS Version: 6_1_7600
  Service Pack: 0_0
  Product: 256_1
WER-46441-0.sysdata.xml
LG G3 Vigor
