Finding a GPU-block for my 780
Hi,
So i recently started watercooling and im looking to integrate my gpu (ASUS Strix 780 6gb) but i did not find any fullcover blocks for it, only the universal ones(covers GPU-chip only) but i´d have to get heatsinks for the VRM and RAM-chips and thats not as sexy looking as a fullcover block (also much more complicated).
The only lead that i found is a list of blocks (2 to be exact, the ASUS Direct CUII one for the 780) that could fit on it based on visual inspection by ekwb and so i´m not exactly shure. I´ve looked at pictures of the pcb and block to compared the VRM/Ram-chips placement but thats to vague to go out and buy a 100 dollar block just so i can send it back in case it doesnt fit.
So my question is should i go for it and order the ekwb one or does anyone else have a suggestion ?
I really don't want to go with the universal block.
Thanks
You will be ok with our EK-FC780 GTX Ti DCII block. ![]()
