Xbox controller for PC
Solved by Ninety1Nine,
I have both.
The 360 controller is a good choice unless you want the different feel of the One controller.
The 360 has a 9ft. cable built in where the One doesn't even come with a cable. Instead you will have to purchase a cable, where you can choose how long you want the cable. Also, its a micro-USB connector. There isn't a wireless dongle to use the One controller wirelessly with a PC yet.
