Is my System Capable ?
Go to solution Solved by Akolyte,
Yeah, GTA V recommended specs is an i5 and a GTX 660 (I think), so its pretty well optimized.  I would say 60fps medium should be no problem, but I would honestly say you could play it at ultra if you wanted.  Dying light, I've never played or seen.  So, I can't help you there.
But know, your system is actually pretty decent.  It is capable of running allot of games at ultra given the fact you don't mind 30fps.  If you want 60 medium is the only way.   But your system is capable.
So, to summarize.  your system can play any game, just not ultra and V-sync must be off, if your not getting 60 fps and you have it on, your just decreasing your frames.
I have a question for you guys?
Is my pc capable for playing the latest Big titles like GTA V battlefield 4 and dying light.
I dont care about cranking the details medium is good enough and i also dont need AA
Specs
I5 4460 3.2 Ghz
Asus GTX 750 ti
8Gb ddr3 1866 mhz
1080p display
Asus Z79-P
https://linustechtips.com/topic/348758-is-my-system-capable/
https://linustechtips.com/topic/348758-is-my-system-capable/#findComment-4746548
GTA V 60fps at low settings (they are called "normal" in this case)
BF4 is not that hard to run (easier than GTA V) so medium-high :)
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/348758-is-my-system-capable/#findComment-4746559
You've got a really nice CPU but a low end GPU, which is more important for gaming. GTA should run decently on your computer but you will have to turn down many settings. Probably the same story for other new games
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/348758-is-my-system-capable/#findComment-4747117
Yeah with Vsync on is is laggy
https://linustechtips.com/topic/348758-is-my-system-capable/#findComment-4749456
