Possible overheating?
Go to solution Solved by LIGISTX,
85 is a safe temp. It is a bit on the high side for me, but I used to run my air cooled 470 at more like 90 under gaming load (it is now ghetto water cooled). You can always try turning the fans up, if you can deal with the increased noise.
Ok i just put in a second GTX460 768MB due to the fact i don't have the money to buy a new gpu. I am in love with the performance increase and the fact i can max out games on a 1680x1050 monitor. The only problem is the top card (Msi cyclone cooler) is running around 80-85c and the bottom 80c (Sparkle stock nvidia cooler). So my question is are these cards running hot or not. Both are overclock with slight undervolting.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/34868-possible-overheating/
https://linustechtips.com/topic/34868-possible-overheating/#findComment-446428
Thanks, im going to try undervolting them some more. I cant stand noise  :P
https://linustechtips.com/topic/34868-possible-overheating/#findComment-446439
haha, yea I feel that. Thats why I ghetto water cooled mine ;). But honestly 85 isn't an issue. Fermi cards run hot,  90 isn't even "an issue" although there is no chance I would let my cards get that hot, at least not often.
https://linustechtips.com/topic/34868-possible-overheating/#findComment-446929
