Hey guys! So, I've decided to update my current build to match my favorite color - yellow! And to accomplish this, I used my previous setup which you can view in my image gallery consisting of a red, white and black ASUS RoG theme. For this task, I decided to replace the motherboard, change out my water cooling tubing, change my power cables and spray paint my case, ram heatspreaders and cpu waterblock faceplate with Plastidip! Let me know what you guys think. :)
P.S I apologize why some of the images are upside down even after I rotated them. :/
i7 4790K - MSI XPower Z97 AC - 32GB DDR3-2400 Avexir Sabranco - ASUS Strix GTX 980 SLI - ASUS Xonar Essence - Phanteks Enthoo Primo - RoG Swift + Samsung 28" 4k UHD - Logitech Z906 5.1 - Custom Water Cooling Loop
Mobile: Samsung S8 Plus | Headphones: Audio Technica ATH-M50X / ASUS Strix Pro | Laptop: Alienware 17 R2
https://linustechtips.com/topic/348665-project-yellow-irradiated/
All that to play Minecraft?
please say you play something that actually uses all that hardware.
Other than that the only thin that bugs me is your one white radiator =P
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
ERROR 404: YELLOW NOT FOUND.
I like yellow :)
Good Job!
Thanks, love me some yellow.
If it can play minecraft, it can play anything.. haha.. nah, i'm digging Farcry 4 right now... I couldn't find a yellow radiator and I didn't want to reduce the cooling capacity by spray painting it..
You can at least do the base right?
Not the fins lol xD
Not the fins lol xD
Yeah, I just thought that the coolant also flowed through the exterior sides of the radiator?
What if you painted it yellow and added a second radiator to compensate for it? Tat would be ballz...
Although black still goes VERY well with yellow, more so than any other color (imo).
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Toxic green would fit the theme better. Also you need at least one radiation symbol to complete it.
I have an applique which doesn't really show through the side window..
Hmmm... I already have 2 360mm radiators.. I don't think I could add another 360mm but maybe a 240mm.. hmm.. I was thinking of getting some yellow 3m vinyl and line the outside of the white radiator..
You should be totally fine to paint the sides/shroud of the Rad, Coolant doesnt flow through the sides even if it did the cooling really only happens in the channels connected to the fins
Any confirmation on this?
