Now i was about to buy seasonic eco 600w for my r9 280x vapor-x tri-x but the seller stopped me saying no its 2x rails and ur card needs 1 rail and it will be bad for ur card.. and my budget for the psu is around 530LE here in Egypt so i decided to create a topic here and some of you said it works well and others said no he is right multi rail will be a problem for your card.. then i decided to choose another psu and i have to pay more 20LE and it costs 550LE which is
Thermaltake Smart SE 630w PSU
so guys this psu is good enough for my r9 280x vapor-x tri-x "focus on vapor-x tri-x"  and it has 2x 8-pin or 2x 6+2-pin ? , or should i just buy the multi rails seasonic eco 600w  ? please help me im serious and my uses for the card is only gaming, thanks !
https://linustechtips.com/topic/348513-another-serious-question/
as far as i know It doesn't really make a difference
http://www.antec.com/Believe_it/PSU/Myth2.php
https://linustechtips.com/topic/348513-another-serious-question/#findComment-4743388
Depends on the PSU. On weak PSUs the rail that supplies the GPU might not be strong enough to run it (happened with my old Bequiet 480W and a GTX580). In that case using a molex to 6/8pin alleviates the problem tho.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/348513-another-serious-question/#findComment-4743434
but some said it always shut down because there's 1 rail of these 2 rails always get overloaded and shut down the whole pc, and i meant overloaded by gaming ..
if its a super poor quality PSU, that might be the case, but a decent PSU should be splitting the load across the rails
https://linustechtips.com/topic/348513-another-serious-question/#findComment-4743445
so the Seasonic eco 600w 85% efficiency is  weak psu or not ?
https://linustechtips.com/topic/348513-another-serious-question/#findComment-4743446
even if its multi rails ? , btw my card is r9 280x vapor-x tri-x 3GB gddr5
as long you run the dual 8 pins or 6+8 pins
that PSU you got is plenty for the 280x
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/348513-another-serious-question/#findComment-4743511
Its fine... it has 24A on each rail which means the GPU connectors can handle more than 280W (more than enough for 280X)
https://linustechtips.com/topic/348513-another-serious-question/#findComment-4743817
