Corsair C70 case fan placement.
Solved by blackadder,
sounds great! be sure to place the top fan in the rearmost spot. You can cover the sides with cheap foam, less noise, less dust, better air pressure.Thanks! What do you think of this configuration? Noctua NF-A15 140mm fan on the bottom (as an intake) another on top as an outtake, one 120mm Noctua NF-f12 on the back as an outtake, and two of those as intakes on the front. This seems pretty good to me as I feel the air is flowing to a place where it cools my components but also forces that hot air out consistently as well.
