my case has 4 fan placements, 1 at the top one at the back front and side i have 3 fan (front back and side all intakes) i am wondering is there a more optimal way of cooling my pc even if it only drops a few degrees. my cpu is cooler by the hyper 212 evo and my gpu the arctic accelero twin turbo. any help would be highly thankful
main rig: http://uk.pcpartpicker.com/p/GFvH7P
next upgrades. h440 . 8320.  possible liquid cooling AIO
https://linustechtips.com/topic/34768-fan-configuration/
What case do you have?
The best is having:
Front >
Back <
Top <
Side >
> = Intake
< = Outtake
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
https://linustechtips.com/topic/34768-fan-configuration/#findComment-445201
i have a rather cheap one but here is a link to the site http://www.novatech.co.uk/products/components/cases/cases/cas-732.html
the thing is i only have 3 fans so which one should i sacrifice for the moment?
https://linustechtips.com/topic/34768-fan-configuration/#findComment-445210
@maddogl
I would put 1 in the front, and 1 in the top.. if your temperature is high on the GPU you could put one in there, if not put it on top.
On my case i have 2 intakes (230+200mm) and 4 outtakes 3x120mm (radiator) and 1x140mm fans^^
I know my case is a bit bigger, but as long as you have 1 intake it should be fine. But test the temperature with and without a fan in the sidepanel for your GPU :)
Also the easiest thing would be just buying yourself a fan on ebay or something. You can get pretty decent case fans from 5 USD and up :)
https://linustechtips.com/topic/34768-fan-configuration/#findComment-445222
