Hey Guys I have already decided on the MSi z97 sli krait edition but then i've read the review by Overclock3D (http://www.overclock3d.net/reviews/cpu_mainboard/msi_z97_sli_krait_motherboard_review/13) and now im insecure if i have made the right decision. If I havent please give me an option (should be either black or white or both) my budget is about 116€ (since this is the cheapest u can get it for in germany. ;/ im confused HELP MEHH!
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/347415-mobo-help/
okay...are there any affordable withe/black/both options?@techguru
https://linustechtips.com/topic/347415-mobo-help/#findComment-4735416
But I dont think it was a Z97 chipset or even a 1150 socket
https://linustechtips.com/topic/347415-mobo-help/#findComment-4735924
yeah thatsmy problem ;/ do u know wich of them would be the easiest to mod ?
https://linustechtips.com/topic/347415-mobo-help/#findComment-4736708
https://linustechtips.com/topic/347415-mobo-help/#findComment-4744561
