Hey so I am going for Austin Evans's $1000 PC build. There is only one problem; the motherboard is out of stock. Is there any others that are compatible and wont need me to change anything else?
MSI H97 Guard Pro: http://amzn.to/1xtIhyG
*Note* I am British so please make sure any links etc the products can be shipped to the UK*
https://linustechtips.com/topic/347363-is-this-compatible-i-need-help/
I vote we totally overhaul this build except the case cause i like that case =P
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
Any mobo in that price range will do it. What Austin puts in the video are only suggestion. Motherboard dont have an effet on performance. Just find another h97 chipset based motherboard that has the features you are looking for and you are good to go.
Cpu:i5-4690k Gpu:r9 280x with some other things
Thanks guys for the replies I honestly didn't expect any! No my budget is not £1000. @DarthVader1022 is the Gigabyte Z97P-D3 Intel LGA1150 Z97 ATX Motherboard compatible with the rest of the build? You see I am only 14 and I don't know whats compatible and what isn't. I just want to make sure, as my plan is to buy everything (except for the motherboard of course) on Austins build therefore its exactly the same and I know it should work fine.
He is using a LGA 1150 motherboard so the CPU,RAM,GPU he is using will all work in any off the motherboards I link you to..
You may also want to correct the text you posted as it was all black and almost did not see the rest of the text you posted so make sure the text is in white since the back ground is black..
