geforce drivers help
Go to solution Solved by Superspeed07,
i want to reinstall my drivers because it doesnt want to start up/crashes when i click it but i cant find the uninstall in the control panel.
many thanks,
fassivemaggot
Just re-run or re-download the drivers you want and check the clean install box
many thanks,
fassivemaggot
OAS || AAS || LLS
https://linustechtips.com/topic/347349-geforce-drivers-help/#findComment-4728956
