What do you guys think about this build?
Processor: Intel Core i5-4460 Boxed
Motherboard: Asus H81M-A
Videocard: EVGA GeForce GTX 970 4GB FTW ACX 2.0
Internal hard drive: Seagate Desktop HDD ST1000DM003, 1TB
Case: BitFenix Comrade Black
Memory: Crucial Ballistix Tactical BLT2C4G3D1608ET3LX0CEU
Power supply: Seasonic G-series 360 watt
Solid state drive: Samsung 850 EVO 120GB
Can i get more then 60 fps at high settings on 1920X1080 while recording with Nvidia Shadowplay?
Thanks for you're time
https://linustechtips.com/topic/347240-help-meh/
First of all, not where and how to post a build :)
http://linustechtips.com/main/topic/95599-linus-tech-tips-forum-code-of-conduct/
You will definitely be able to do what your wanting, but I would put in a slightly higher wattage PSU for good measure
Other than that its pretty solid, you can get into 1440p ground with that setup
https://linustechtips.com/topic/347240-help-meh/#findComment-4727349
-SNIP-
For that setup you have I would suggest something of a slightly larger PSU especially if you plan to overclock the 970 GPU, right now you on basically the required minimum I personally like to have max capacity at around 80-90% the max capacity of the PSU.
https://linustechtips.com/topic/347240-help-meh/#findComment-4727360
I'm particularly not comfortable seeing a 360w PSU for a i5+970 build. I'd make that 460w minimum, 500-550w recommended.
Honestly I'm not that fond of ASUS boards, but that board does seem a bit too cheap. I'd try to spring for a Z97 chipset motherboard if I were you.
But this is all entirely on your budget and where you live. If you just want your question answered, yes you should be able to get 1080p60fps with ease while recording.
https://linustechtips.com/topic/347240-help-meh/#findComment-4727387
Thanks for you're tip but on my budget i dont think i can afford a more expensive one :S
My power supply now is the Cooler Master GM G550M
https://linustechtips.com/topic/347240-help-meh/#findComment-4728106
I dont know what a PSU is :P
https://linustechtips.com/topic/347240-help-meh/#findComment-4728116
https://linustechtips.com/topic/347240-help-meh/#findComment-4728118
Soo, this is acctually not bad, but i would upgrade the Mainboard, and the RAM [to 16 GB]
If you want to record, dont do it with Nvidia Shadowplay, use more likley Fraps, Overwolf or an external recorder, somthing lika a capture card,
I dont like the case, but i guess thats your choice :) otherwise i would add a more powerful PSU somthing like 650W will be fine :)
Hope i could help you
https://linustechtips.com/topic/347240-help-meh/#findComment-4729361
Thanks, i didn't realized yet i needed more ram. The motherboard needs to be better. Thanks for the tips :)
https://linustechtips.com/topic/347240-help-meh/#findComment-4733720
Yes B85 will be good too, but i was asking to buy H97 for future proofing
Although if u buy B85 go for Asus or gigabyte as they will provide Pcie 3.0 intead of 2.0(better for your gpu) and they will provide extra usb 3.0 ports.
For SSD they are meant for boosting up the speed whether for os or whatever, so if u r out of budget u can buy an hdd and consider the ssd sometime later
https://linustechtips.com/topic/347240-help-meh/#findComment-4735814
Does it boost the pc performence in games or just when you turn it on?
https://linustechtips.com/topic/347240-help-meh/#findComment-4735971
It speeds up the booting by a lot, and depending on if you have games installed on it, they will also load faster.
Laptop: Intel Core i5-4200H, 8GB RAM, 750GB HDD, GeForce 840M
Desktop: Intel Core i3-6100, 8GB RAM, 750GB HDD, GeForce GTX 750 Ti
https://linustechtips.com/topic/347240-help-meh/#findComment-4736616
let me give you can example, 12 years ago i use Pentium 3 with 500mHz or so with an IDE 40gb hdd, right now i use an i5 with 3.4gHz and 1Tb Sata Hdd and an SSD, the point is technology changes almost every week
So if u r buying and 1Tb HDD in 50$ right now, u can also get a cheap ssd in near future
So don't bother if ssd is not included in your budget
Without SSD my system takes around 5 seconds to boot up which is pretty fast i guess
https://linustechtips.com/topic/347240-help-meh/#findComment-4760664
What are you're pc specs?
https://linustechtips.com/topic/347240-help-meh/#findComment-4765510
The Coolermaster will be ok to reuse. It is a decent (If not spectacular) unit made by Channel Well.
http://www.techpowerup.com/reviews/CoolerMaster/G550M/11.html
https://linustechtips.com/topic/347240-help-meh/#findComment-4765545
Motherboard : Msi Z97 Pc Mate
Processor : i5 4690
R.A.M : Corsair Vengeance 8gb x1
Gpu : Asus Gtx 970
Psu : Corsair Vs 550
Case : Corsair CM Force 500
https://linustechtips.com/topic/347240-help-meh/#findComment-4771292
