Question about fan setup in H440
1Scotty1
Hello,
don't know if this is the right sub-forum, but whatever :P
Right now, as I am waiting for the arrival of my second backplate and some Aerocool DS 140mm fans to finish up my build, I have been thinking about fan setup in my H440.
Currently I have it like this: 3x Noiseblocker eLoop B12-3 in front as intake, 1x AF140 as rear exhaust and X61 on top as exhaust
And I am thinking of this (pic included):    X61 on front as intake (filtration taken care of), 1x AF140 as rear exhaust, 2x Aerocool DS 140mm on top as exhaust
Now, I want your opinion, or suggestions on my fan setup
Thanks, cheers
Hello,
Thanks, cheers
Looks like my diagram :D. Aerocool fans ftw
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
I just made it in MSpaint :D bored at work, so experimenting :D so, option two it is? :)
I think in your case, it will be negative airflow which will have more dust (something like that, personally I'm not too sure as well). Usually what I heard is to have front and top to in intake into the case and rear to exhaust to maintain the positive airflow, so that there won't be so much dust collected in it.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
looks great, you always test each way it will only take a few minutes. i like having alot of intakes on top just to cool the pch and other components a little better, i would rather have the air hitting them then have the air above them being sucked away more dust, just me though.
I made mine in Photoshop D:
Main Rig
 XENON Build:
Office Build:
Phone
-snip-
Dem skillz :D and you have it like this?
Similar but Im using H80i and the radiator is mounted on the top-front
Main Rig
 XENON Build:
Office Build:
Phone
No negative pressure?
And yeah, I want it like that also, X61 on front as intake, Aerocools on top exhausting and rear exhaust also... and sell/giveaway the 3 Noiseblocker eLoops :D
Working on that, waiting for the X61 to go back in stock. The H100i GTX isn't catching my eye as much, some reviewers have said the tubes are very stiff, also I prefer the H100i look but hey, I like to be up to date, therefore X61.
Main Rig
 XENON Build:
Office Build:
Phone
I had the H110, but twice RMAd... X61 had no problems yet :) and I will put it as intake at the front and be done with it, whatever :D:P
