If I were to get a second 780ti to SLI with my 780ti Direct CUII, should I get the reference cooler or the ACX cooler? I normally would go with the ACX cooler but the problem is that I have a mATX case meaning the cards will literally be 5 mm away from each other if not less.
If someone wants to buy my current 780TI, that'd solve my situation too  :P
Desktop: The Bluez | CPU: i5-3570k @ 4.5 ghz 1.296V | CPU Cooler: Hyper 212 Evo | Motherboard: P8Z77 M-Pro | Memory: 16 GB 1600Mhz Kingston HyperX
GPU: Asus GTX 780ti DirectCu II | HDD: Some Random Hitachi 1TB, WD Blue 1TB, 850 EVO 500GB | PSU: Rosewill Hive 750W | Case: Enermax Ostrog GT (Blue Ver.)
Laptop: Razer Blade 14 2013 256GB
https://linustechtips.com/topic/346889-reference-vs-aftermarket-for-sli/
I'd say reference is better as there is the blower style fan, but get ACX if OC'ing. The reason blower style is better, is that it doesn't push air down the card, it goes through the  card out to the back of your case.
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
Hm... What configuration should I put it in then? Bottom -> Top: Blower -> Aftermarket or Aftermarket -> Blower
