https://linustechtips.com/topic/346830-help-with-hdd/#findComment-4722021
It's an old IDE hdd, it uses a big-ass IDE cable for the data and a molex connector for power. It's a 4-pin plug.
You also have to check if you want to use it, if it's in the right mode.
Most IDE drives have 3 modes: master, slave and cable select.
If it's only 1 hdd, just use master. You can change it with that white thing that's plugged in, there should be a schematic of the right options on the hdd itself.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/346830-help-with-hdd/#findComment-4722043
Can I use molex? I have spare
yes. but your pc  might not recognize it
https://linustechtips.com/topic/346830-help-with-hdd/#findComment-4722058
It doesn't look like that hard drive supports SATA data cables. Do you have a flat thick ribbon cable and a corresponding slot on your motherboard? Picture is kind've blurry but it looks to me like you have a SATA data cable in your hand. And it looks like that is an IDE-only hard drive
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/346830-help-with-hdd/#findComment-4722262
Hmmm looks like you will need a SATA Power to Molex converter. Please say you have an IDE cable and port on your motherboard. If so that's good. If not well looks like you will need to get a SATA HDD. If the drive will just be used for storage the other option is that you can buy a HDD dock or a External enclosure for it.
https://linustechtips.com/topic/346830-help-with-hdd/#findComment-4723388
What do I do with the sata.
http://m.imgur.com/1TFSmxV
Hey Oppslia,
It would be helpful if you could provide us with the exact model of the drive and your motherboard. Usually you can use those drives with a simple IDE to SATA converter card or adapter. They tend to be pretty inexpensive.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/346830-help-with-hdd/#findComment-4724872
