Hello,
Im a student and i program and develop ALOT, sometimes stuff takes way longer to compile and debegging is a problem etc, etc. I want to build a pc that is superfast and silent,along with power efficiency regardless of budget. currently i am planning to go with:
Processor: i7 4820k
MotherBoard: z97 deluxe asus
RAM: 16GB ddr3 of any brand
Storage: Samsung 850 Pro 1TB, 850 Evo 1TB
Graphics: Some graphic card that supports 4k resolution (any suggestions??)
PowerSupply: 600Watt with 80+ gold and above (any suggestions??)
now i dont any sort of experience with how to make this build silent..any coolers would greatly be appreciated.
Thanks
https://linustechtips.com/topic/346747-best-build-for-programmer/
-snip-
4820 and z97 is a big nono.
You need a 2011 mobo for that chip.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
Well the 4820K is a last gen Ivy-E part on LGA2011-2 so I assume you mean 4790K (which is fine).
Z97 deluxe probably not necessary here... look for something a bit cheaper like the Z97-A.
Hello,
Processor: i7 4820k
Thanks
An I7 is more than needed for programming.
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
I currently have first gen i5 760 and my cpu usage is 100% when compiling...so what do u recommend??
I use a i5-4670 and my CPU is at a max of 75% when i compile programs and do other things on my system. So a 4670 or a 4690k.
Hello,
Thanks
are you serious? this is like most people on here dream, kid in a candy shop thing, building a high end computer and budget don't matter?
you must have some kind of budget? or preferences, like form factor, storage space needed, colour scheme, any prefered manufactures?
was all have different ideas and need a bit more information so we can recommend something that is close, also your location country so we can recommend a dealer or store to get components from.
well i will give you a little idea of what i think would be a good rig as i do a little bit of code myself and my bro is a programmer so we build computers and love it.
for the start a works / programming computer is way different than a gamer / entertainment computer, however some of the principles are simular.
everyone wants speed. and everything comes with a trade off, more speed more heat etc.
I would recommend a few of the following:
Intel X99 chipset m/board in ATX or M-atx if you want a smaller compact power house build.
Intel 6 or 8 core i7 2011v3 cpu
120 gig as min, 240 gig ideal SSD or M.2 SSD (better option on a new build nowadays) for operating system. (maybe both if you have multiple O/S)
quality hard drives or a pci-e SSD type card for main works hard drive, even a SSHD (hybrid) would work to save cost, you would need a 1TB or more unless you plan to keep lots of back ups and then you could just go with a pci-e SSD card with 480 gig.
nice case with option to line it with soundproof foam sheet or just a quiet case (windows are nice but not needed)
good quality aftermarket all in one sealed liquid cooler (single or duel is better) also you can swap out the fans to better ones to save noise.
optical drive / blu-ray player is nice to have.
good graphics card with lots of onboard memory (4gig or more) a Titan would also be a good work station GPU. or a Mars with 2x gpu's on one card. for quiet and effecient a Strix 970 would also do and if needed get another later on and go sli.
lots of fast quality memory that works well with the m/board and is futureproof, 16 gig is min and 32 gig is ideal.
power supply, lots out there, just get something quiet, enough power and good build quality.
extra fans and some lighting etc if you like to display the components.
a good comfy keyboard and mouse is recommended (look at the new microsoft split / curved keyboard)
a 24" 1080p monitor LCD LED with 5ms or less responce time is a must. you can also go bigger or get 2 of the same. i thing duel 24" setup would be best.
i am sure i have missed some stuff but thats the basics, you need fast quiet interfaces, reliable components.
i can make a build if you liek, some kind og budget would help, unlimited is just to good to be true. haha
hope this helps
got to love Asus components
ok so since u mentioned about the budget its around 8~10k dollars..why?? i worked as counsellor and earned handsome amount which i saved for 4 years..now the time has come to spend it all as i have started to do insane programming, java phython c# and insane linux usage almost..i dont wanna build to game..productivity is main concern..imagine running two OS'es side by side and requring everything in a jiffy..i recently bought a 4k monitor and i just need a PC..install it with a$$ kicking components that will make my current work easier and fly.hope this clearifies
As someone with a $10,000+ build... don't do it.
For what you're doing, get a single 970, a 5820k, 32/64GB of RAM, and a few SSDs... I can't see a need to spend more than $5,000 on a programming build.
