Hi all, I am looking for help to find parts to finish updating my build. Currently I have a GTX 970, power supply (850W) and hard drives (128GB SSD boot drive and 3T storage). I found the build guide template so I will just use that :)
1. Budget
$1000 at the most
thing I need are:
-Motherboard
-CPU
-Ram
-Case (my old one is fine but it's just a cheap one that I got with the leftovers from my last upgrade)
-Cooling (only if I have leftover money, I don't overclock but kinda want to start)
2. Aim
Decent gaming pc, 60+FPS (obviously) not looking for 4k yet. Also I like to upgrade around every 2 years so things that will be fine till then would be good.
3. Monitors
Already have what I want, 27'' and a 24'' 1080p.
4. Peripherals
Already have.
5. Why are you upgrading?
My Intel Core i5-3330 CPU and GA-B75M-D3H motherboard aren't pulling their weight anymore with the new GPU I put in also there are some small issues that I can't really be bothered fixing since I'm due for an upgrade anyway.
Thanks.
https://linustechtips.com/topic/346583-half-build-help/
