guys, i have an fx 8320 and an asus m5a99fx pro r2.0 motherboard , 8 gb corsair ram 1600 ddr3, sapphire r7 260x gpu
sometimes i am getting frozen screen, or the usb devices like mous and keyboard are not getting detected in any of the ports ( front and back panel), and sometimes just bluescreen with pmd...
i can not figure out the issues...i updated all drivers to the latest ones....still the issue remains...
by the way i have no overclock and my cpu cooler is corsair h80i...
the temps in the bios are fine...around 40c...
i dont understand the issue....
https://linustechtips.com/topic/346296-motherboard-issues/
you chould update the chipset and USB controller drivers. check if everything looks fine in device manager
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/346296-motherboard-issues/#findComment-4715958
I have similar issues, as far as I know its an issue with amd drivers. You can use WhoCrashed to get a little bit of info if you get more bluescreens, but the results may not be too helpful. http://www.resplendence.com/whocrashed_help
Corsair Obsidan 750D - ASUS Crosshair V Formula - AMD FX-8350 (stock) - Sapphire R9 290 Tri-x  Ghz OC 4GB - Samsung 840 EVO 256GB (OS) - many other drives (11TB total) - 23" hp LV2311 (main) + 2x 23" ASUS PA233QR (peripheral) monitors - CM Storm Quickfire Ultimate (cherry browns) - Razer Naga 2014
https://linustechtips.com/topic/346296-motherboard-issues/#findComment-4715994
