Alright I've had an Acer pc for about one and a half year now, and it has started to run in to problems. The problem is that the pc works fine for about five minutes, but then it slows down to a crawl and it then proceeds to freeze. The only way to get it to unfreeze is to reboot it. So, if anyone can help please do so.
https://linustechtips.com/topic/346218-pc-help/
sounds
sounds like it could use a good cleaning...both inside and out
I would clean out the dust from it
and then do a clean install of the OS ...don't forget to backup your data first tho
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/346218-pc-help/#findComment-4714830
Boot it up in Safe Mode and see if it still has the same issue. If so it very likely is a thermal issue.
Also - Have you checked it for virus' and/or maleware? If the issue is still there in Safe Mode, try to run a Malwarebytes and AV scan to see what they find.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/346218-pc-help/#findComment-4714844
