NAS problem - help needed.
Solved by Brandonberg,
Run FreeNAS from a thumb drive. I believed it is optimised for use this way. Then add your free HDD as a volume.
edit: Have a look here
http://doc.freenas.org/9.3/freenas_intro.html#compact-or-usb-flash
The FreeNAS® operating system is installed to at least one device that is separate from the storage disks. The device can be a USB stick, compact flash, or SSD. Technically, it can also be installed onto a hard drive, but this is discouraged as that drive will then become unavailable for data storage.
