Help with Airflow
Go to solution Solved by Toxicable,
I want to know what would be the best airflow setup, in my case, at the moment I have
  • TOP = 2x 140mm Noctua IndustrialPPC 3000rpm PWM (Intake)
  • FRONT = 2x 120mm Bitfenix Stock (Intake)
  • BACK = 1x 120mm Noctua IndustrialPPC 3000rpm PWM (outtake)
  • And I have a NH-D15 configured with one fan (could not fit the second in my case) to blow out the back
I would like to know the optimal airflow and whether I should have stuck with 2000rpm fans.
My case is the Mid-tower Bitfenix Shinobi Windowed
As for the rest of my specs, they are below
Intake at the front/bot or side, exhaust at the top/back.
Hot air moves up, therefore having a intake at the top is ineffective.
Main PC: CPU: i7-4770k RAM: 16GB Kingston HyperX Blu SSD: Samsung 850 Pro 256GB HDD: 1TB WD Blue GPU: ASUS GeForce GTX 770 2GB PSU: Corsair CX600M Case: Bitfenix Shinobi OS: Windows 10 Pro 64-Bit
Laptop: ASUS N56VJ
https://linustechtips.com/topic/345565-help-with-airflow/
https://linustechtips.com/topic/345565-help-with-airflow/#findComment-4706341
The industrial fans are kind of loud.
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/345565-help-with-airflow/#findComment-4706348
