Hello folks.
The computer with the specs below has started to only boot after hard reset, two weeks ago.
CPU: 3770k
MB: Sabertooth Z77
RAM: Corsair Vengeance 4x4GB
GPU: EVGA 780ti
HDD (Windows): Kingston SSDNow V300 120GB
HDD (Storage): 9 disks (Samsungs, WD Reds...)
PS: LCPower - LC8850
I did a CMOS reset and turn off all hard drives but it didn't solve the problem.
I also changed the power supplier a few days ago and it has been working properly but today it didn't boot again (only after reset).
EDIT: I've tried installing the OS in another SSD..
Does anyone happen to know what it may be?
Thank you for the support.
Cheers.   :)
https://linustechtips.com/topic/345318-pc-only-boots-after-reset/
Terve!
I might not be the right person for that problem, because I have to ask: "What is a hard reset?".
Personally, I would check the switch of the case (unplug the connector and use a paperclip, if it works its the cases switch) and I would also see for wake on LAN configuration.
That thing screwed me over once. The only way I could boot the PC was to unplug the power and replug it.
Google for a guide to check the WoL status of your board.
Sayonara!
  • 2 weeks later...
