So I just recently got a brand new GPU. (The G1 Gaming 960 to be exact.) I installed it, after a lot of problems, got the drivers; and it worked fine. I getting over 250 fps on Minecraft and one time I hit 303. Then I turned it off for the night. Next morning I turned it on to actually do some tests and my PC let me type in the password, then would freeze. I can't get to my desktop at all so I have to use the console. My father said that he did some updates last night and I'm guessing something didn't like it. I've gone into my console and whenever it tries to go to my desktop it says hda codec: out of rang cmd 0:7:707:ffffffff. I don't think it's my hardware as it was running fine before the updates. I am running Ubuntu 14.04 LTS. My system specs:
CPU: i3 4150
Motherboard: H97M Anniversary
Ram: 8GB Kingston Fury Series
HDD: 160GB WD Blue
GPU: G1 Gaming GTX 960
PSU; EVGA 500W B1
Anyone have some ideas on how to fix this?
PC and Peripherals:
Intel Core i3 4150 @3.5GHz - ASRock H97M Anniversary - Kingston Fury HyperX Black 8GB DDR3 @1866MHz - Gigabyte GeForce GTX 960 G1 Gaming 2GB GDDR5 - EVGA 500W 80+ Certified - WD Caviar Blue 1TB - WD Caviar Blue 160GB - Lian Li PC-50 - Linux Ubuntu 14.04.3 LTS - Acer P221w 21.5" 1680x1050 60Hz - Kingston Fury HyperX Clouds - Razer Deathadder 3.5G - CM Storm Quickfire Rapid w/ Cherry MX Blues
https://linustechtips.com/topic/345223-problems-booting-in/
Alrighty, I'll have to try that out later. Is there a way to undo updates though?
PC and Peripherals:
https://linustechtips.com/topic/345223-problems-booting-in/#findComment-4702583
