at school i use a dell latitude E5530 and it gets to 70-75 degrees celsius, should i contact IT about it?
(didnt do that with an optiplex 310 that throttled at 100 degres every day for a month and that died a week later)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/345064-latitude-e5530-temp-problem/
Under what load?
But yes that high.
Under what load?
But yes that high.
at idle :wacko:
My pc:
(Black Glacier)
My server:
if its still under warranty
yes contact Dell
their tech support has improved a lot
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
just went to IT, he gave me a laptop cooling pad and told me not to worry. (he wants newer pc for school)
My pc:
(Black Glacier)
My server:
Dell Laptops have the worst cooling ever. RMA it or if the warranty is still valid let it fix for you.
read earlier post. he dosent give a fu*k about those computers, he just hads out cooling pads for the laptops that get werry hot (there are only a few of them)
My pc:
(Black Glacier)
My server:
my dad is using the i5 Core-3337 laptop and no issues of cooling
except the loud fan when it kicks in
not a IT guy alert
the fan on this is at 100% all the time blowing scorching hot air at my hand.
My pc:
(Black Glacier)
My server:
not a IT guy alert
yep, he has to send computers to dell if the system fails (windows reinstalation will solwe this, but he dosent know how to do it)
My pc:
(Black Glacier)
My server:
the recovery image is in the HDD
just activate the recovery and it will reset the PC to the original state
Yeah most IT guys don't give a damn fck, also contacting Dell yourself is pointless.
you need to correct that
My daily job is the office IT guy and i give a fck for 12 hours a day  <_<  <_<  <_<
wish you were IT here....
My pc:
(Black Glacier)
My server:
can i send my resume to their IT manager there? xD
probably not, this school is falling  apart and they are firing teachers to keep going. so nope xD
My pc:
(Black Glacier)
My server:
