Basically looking to end up with 3 monitors, don't know what to do.
My current setup is one BenQ RL2455HM that WILL be getting an upgrade sometime soon, and a Dell 2001FP to the left, and portrait.
My idea is to get rid of the 2001FP and replace it with two Dell Ultrasharp 1909w's, but unfortunately, their resolutions are pretty... bleh. 1440*900, pixel density is okay, but I'll be downsampling for sure because I downsample everything :D
This is the ebay listing for the 1909w's:
http://www.ebay.com/itm/Dell-Professional-1909W-19-LCD-Widescreen-Monitor-5ms-300-cd-m-1440x900-USB-DVI/321681547355?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D2%26asc%3D29384%26meid%3D49ec21a6654d4f8c8d5bff83a65561c6%26pid%3D100010%26rk%3D3%26rkt%3D20%26sd%3D171483208528
Either that or I could get one more Dell 2001FP (great resolution, 1600*1200) but i personally don't like 4:3 that much.
http://www.ebay.com/itm/Dell-UltraSharp-2001FP-20-TFT-LCD-Monitor-DVI-VGA-1600-x-1200-4-3-400-1-/171718759325?pt=LH_DefaultDomain_0&hash=item27fb3c539d
OR you guys could recommend another monitor (2 of the same type please) under $80 for both.
The reason for this cheap surround idea is because I do a lot of flight simulator and surround is a VERY nice experience with FS.
Thanks
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/345034-cheep-surround-solution/
1920x1080 LG24EN43, they are good gaming monitors when your on a budget, though sub $80 is difficult.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/345034-cheep-surround-solution/#findComment-4716305
i suggest you dont waste time on any of this shit and skip a few happymeals and get lg 29um67... its the cheapsest 21:9, just a bit over your budget, oh and its also IPS, 75hz + freesync
you`ll have a way better time on that than any shifty joke setup
https://linustechtips.com/topic/345034-cheep-surround-solution/#findComment-4716516
