Hard Drive Help
Solved by WoodenMarker,
Update:
I tried what "WoodenMarker" suggested, but encountered a problem. On the SSD is a folder called "Program Files" and "Program Files(x86)". These folders properties cannot be moved to the storage hard drive, which is what I want to move (the applications I've downloaded such as Steam, Chrome, Skype, etc.) Any help?
*Side note- Thanks everyone for helping out, I know it must be frustrating to be helping someone as new as myself.
You shouldn't be moving those folders. Applications should stay on your ssd.
One last question, is there any way to move over the applications I've already downloaded or is this just for future downloads? Thanks for the help.
Install programs on your hdd if that's where you want them.
