Afterburner problem
Solved by SkixAces,
ok so then it is confirmed a driver problem and when you're sure it is solved please use the solved button just play for a while first though to make sure hope all goes well on the stock drivers
It seems to be sorted on the newest driver (14.12, not the beta driver)
Im not sure what did the trick, I did the following:
*cleaned the pc with compressed air
*reseated it again
*Followed this faq to delete the driver: http://support.amd.com/en-us/kb-articles/Pages/GPU57RemoveOldGraphicsDrivers.aspx
*I deleted msi afterburner.
After I did all of that I installed the newest driver and the problem seems to be gone
To be sure im gonna play a quick game of counter strike global offensive, and if its gone I am going to klick the solve button ![]()
