HD 7970 Problem Loading
Go to solution Solved by ZainJ51,
Disable the onboard video in your BIOS, Unplug any video cables plugged into your motherboard and have them all plugged into the video card.
I fixed it thanks, it was the 8 pin connector was a little chipped
So i just got my 7970 and went ahead and installed it and launched up the computer, it loaded up and fans spinning and all so i went into Msi afterburner and it said Intel HD graphics so I went into my bios and disabled the onboard gpu and then save and resetted, I then switched the dvi cable to the graphics card and got a black screen and now even if i put it on my motherboard dvi slot it gives me a black screen.
I am putting it in a pcie x16 slot is that a problem?
https://linustechtips.com/topic/344470-hd-7970-problem-loading/
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/344470-hd-7970-problem-loading/#findComment-4692313
