I have been using Intel's Ethernet Connection I354 network adapter for a month or so on my desktop but it sudenly started to give me problems such as not detecting an ethernet cable. I have NO experience with Windows desktops because i have always had a prebuilt laptop at my disposal. I would really apreciate some help because it is incredibly annoying, especially because i have no idea what to do. My motherboard is the Asrock H97M Pro4 fyi
Case: Corsair Graphite Series 230T | CPU: Intel Core i5-4460 @3.2GHz | CPU Cooler: 2x 120mm Front, 1x 120mm Back | Motherboard: ASRock H97M Pro 4 | RAM: Team Vulcan 8GB (2x 4GB) DDR3 1600 | Graphics Card: ASUS DirectCU II Radeon R9 290 4GB | SSD: Samsung 840 EVO 120GB | HDD: WD Black 500GB 7200 RPM 64MB Cache | PSU: NZXT Hale82 550W 80+ Bronze | Headset: Astro A50 | Mouse: Logitech G602 | Keyboard: Razer Death Stalker (Refurbished)
https://linustechtips.com/topic/344273-network-adapter-problems/
maybe a driver update is needed, if that doen't solve it you should try to contact intel for support, maybe it's faulty
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
https://linustechtips.com/topic/344273-network-adapter-problems/#findComment-4689900
I have used a different driver a few months back and it also worked for about a month and then i switched to the one i have now, and now it starting to fail. I click update and use the drivers on my computer, but i dont know which one to use for my specific set up. PS how long would it take to get a response from intel?
https://linustechtips.com/topic/344273-network-adapter-problems/#findComment-4689953
