hey guys im coming to the linus community today because im trying to build a computer and the im not sure the amount of wattage i would need out of my power supply.
note:(to make its easier for you guys to help me here is my pc part picker list http://pcpartpicker.com/p/K3qDFT )
PLZ HELP!!!! thx
EDIT: im planning on over clocking my cpu to 4.0 G if that makes a difference in the decision also planing on playing very to high demanding games and the pc i have now shuts off when i tend to play those types of games(Note: i bought a solidgear wich i shouldnt have but i did because its was cheap and now i see that its faulty) thx
https://linustechtips.com/topic/344253-psu-help/
PLZ HELP!!!! thx
id say get a 650 w psu if you wanna expand a lil more maybe even a 750w? and never cheap out on your psu ever.
askdjfasdf
https://linustechtips.com/topic/344253-psu-help/#findComment-4689325
I'd say about 850w is good. you never want to have too little wattage if you ever decide to add/ upgrade in the future, it's better to spend a bit more up front vs having to replace it in the future. I'd suggest EVGA, Corsair, Seasonic and BeQuiet! for high quality power supplies.
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/344253-psu-help/#findComment-4689448
I would recommend a Fully Modular PSU (less excess cabling) in the 650W-850W range from a reputable name brand like Corsair, EVGA, or SeaSonic.  I'd also recommend something that's 80+ Gold or Platinum certified - partly because of lower energy costs, partly because of lower heat and thus lower fan speeds and less noise.
Here's a link to a PCPartPicker search for those very criteria: http://pcpartpicker.com/parts/power-supply/#p=1&e=5,4&W=650,850&sort=a9&page=1&m=11,14,71
Any one of those should serve you well for many years.
Edit: More wattage means the possibility of more upgrades in the future without needing a new PSU, like if you wanted to add a third 970 eventually.
https://linustechtips.com/topic/344253-psu-help/#findComment-4689449
Anywhere from 650W-800W or even more. Having more is not going to let you down if you ever need a third 970. Also get 80+ Gold or Platinum because they are better and you get less heat from them.
CPU: i5 4690k @ 4.5 GHZ CPU COOLER: Hyper 212 EVO GPU: Evga GTX 970 SC ACX 2.0 CASE: NZXT H440 SSD: Crucial MX100 128 GB HDD: 1 TB WD Blue MOBO: MSI z97 PC MATE FANS: 6x Corsair SP120, 1x Corsair AF140 Monitor: ASUS VN247 PSU: Corsair CX600M RAM: 8GB Corsair Vengeance
https://linustechtips.com/topic/344253-psu-help/#findComment-4689567
There are various of brands that provide quality PSUs, and as such, you shouldn't limit yourself to just 1-3 of them. Otherwise, you may be missing out to some excellent units.
Anyways, a quality 650w can power that system.
For $79.99 after MIR, the XFX XTR 750w is a good unit to power that system: http://pcpartpicker.com/part/xfx-power-supply-p1750bbefx
It's a Seasonic G unit internally, but offer full modularity, a switch to turn on/off semi-passive mode, and a FDB fan.
Or the high-end Delta build Antec HCP-750 Platinum for $101.98 after MIR : http://www.newegg.com/Product/Product.aspx?Item=N82E16817371083
https://linustechtips.com/topic/344253-psu-help/#findComment-4690980
