Hi guys!
Im buying a 4670k and i want to know which are the best matx mobos for like 100 dollars ( a little bit more or less!! ). I was looking at the Asus Gryphon z87 ( that's a bit over my budget but it seems a well round mobo and its not that expensive) and i want to know if there are some cheaper mobos and equally good ( i know its not gonna be "as good" as the gryphon but you guys understand).
Im not planning to overclock it till the sun, just a mild overclock to play some games and get an extra boost!
Thanks alot!!
https://linustechtips.com/topic/34424-help-choosing-a-new-mobo/
The MSI Z87-G43 is a good mobo for the price: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130694
The Gigabyte Z86X-D3H is also a good choice: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128591
Motherboards below these are not really that good, they have  very poor power delivery systems and use cheaper components.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/34424-help-choosing-a-new-mobo/#findComment-441042
